getting better gas mileage?
I am noticing a slight increase in gas mileage on my s/c and am wondering if anyone else is getting similiar results? i think it's due to the fact that i am learning to drive it a little under rpm's as well? anyone else also seeing the same or simliar results?
It's most likely the novelty of the blower being "NEW" has worn off and you are driving more "Normal" so to speak. In this case.... it is not uncommon to experience bad gas mileage when you first go FI and then it taper down to a more reasonable driving style and gas mileage.
The same can be said for the BOV. If you initially were reving higher to sound off...then after time lose interest... you will see better gas mileage.
Tim
Tim
