Which gauges are needed?
Old 04-11-2010, 07:44 PM
gnehc1's Avatar
the oil pressure gauge can be a stand alone, right? meaning, it doesn't need to be hooked up to the EMS to get a reading...
Old 04-11-2010, 07:54 PM
Former Sponsor
Moddiction's Avatar
Correct.
You just need to tap into an oil source. I definitely recommend going with a Greddy oil filter block adapter to tap into for the oil pressure sender unless you are doing an oil filter relocation then can tap in along the line somewhere.
Old 04-11-2010, 08:44 PM
RedLineS2k10's Avatar
check out STRI gauges, my oil pressure gauge is hooked directly up to my oil filter housing, will post a pic
Old 04-12-2010, 03:34 AM
GPW03's Avatar
Originally Posted by AFs2k,Apr 11 2010, 10:31 PM
MINIMUM of AFR (wideband) and a boost gauge.
That's all I have right now (AEM UEGO and AEM Tru boost), but I'm going to get an oil pressure gauge soon.
IMO this is all you need
Old 04-12-2010, 05:44 AM
JoeyBalls's Avatar
can I get an Oil pressure gauge that just plugs into the EMS to get a reading?
Old 04-12-2010, 05:52 AM
TRBOKEV's Avatar
No gauges here... Just my laptop.
Old 04-12-2010, 06:32 AM
gnehc1's Avatar
[QUOTE=GPW03,Apr 12 2010, 04:34 AM]IMO this is all you need
Old 04-12-2010, 06:53 AM
Chow-bot's Avatar
AEM serial gauge
Old 04-12-2010, 06:58 AM
stitos2k's Avatar
boost gauge and AFR are certainly useful, the rest are what I classify as paranoia gauges.
Take oil pressure for example, a sudden drop in oil pressure is going to send your CEL freaky anyway. Also oil pressure isn't really effected by oil level, not until your so low as to be SOL anyway. Oil temp makes much more sense in my opinion.
An oil TEMP gauge however would be very useful. When your oil level is low the oil gets hotter. It'll also let you know when you've been pushing the car to hard and need to chill out.
Water temp, why? I don't about you guys but I have a temp thing sitting just to right of my speedometer and just above the fuel gauge . I know where it usually reads, if it goes up I'd probably be curious at the least If it was just an idiot light I'd agree, but its not.
Old 04-12-2010, 07:07 AM
JoeyBalls's Avatar
yup
Quick Reply: Which gauges are needed?
