FullBlown Sidewinder oil return location?
Old 08-23-2013, 05:32 AM
GrandMasterKhan's Avatar
Default FullBlown Sidewinder oil return location?
Ohh geez here we go. Another precision smoking turbo thread. I thought I had done a good job with my oil return to the girdle, but Honestly its a bit long since it goes from the turbo all the way to under the passenger motor mount, which forces my return line to have 90degee bend into the girdle. Due to the length and location it makes the return line only at a slight downward slope since it is so long.
So I was thinking of tapping my timing cover to the left of the crank pully as low as I can go. That will make my return line about 8" shorter with a steeper downward angle.
Where are you guys tapping your oil return for your FullBlown Sidewinder setups? Has anyone else had to re-do their return line?
Basically I am trying to figure out if my smoking is due to my return line or if my turbo is bad. What do you guys think?
my setup:
6265 twin scroll (maybe 800 miles)
-3 feed no restrictor (has inline oil filter)
Old 08-23-2013, 05:35 AM
see photos.
Attached Thumbnails FullBlown Sidewinder oil return location?-image-1063929074.jpg   FullBlown Sidewinder oil return location?-image-3712054396.jpg
Old 08-23-2013, 05:54 AM
vduber's Avatar
Its hard to tell from the pics but it looks like you feed does Not sit directly ontop of the turbo (lets call it 0 degrees) nor does the return sit directly in the bottom (180 degrees) in which case oil can get trapped in the turbo and burn off. If thats the case which I believe it is just clock the turbo.
Old 08-23-2013, 05:57 AM
vduber's Avatar
Nvm actually looking at the pic again it looks like you do have it clocked correctly. If its long and basically goes into the girdle parallel id take it off and make it alittle more taught and try to angle the 90 degree fitting up abit
petawabit's Avatar
I have mime tapped to oil pan towards front of pan. If you were looking at the crank pulley, right below it?
Old 08-23-2013, 06:23 AM
thats pretty much where i am thinking of tapping mine. Except perhaps on the timing cover instead.
Old 08-23-2013, 06:38 AM
herecomesboost's Avatar
Tapped to the left of the crank pulley (on the timing chain cover); this is how I have mine:
Old 08-23-2013, 07:26 AM
rammstein688's Avatar
I have it tapped on the front of my oil pan on the drivers side.
Old 08-23-2013, 08:06 AM
Phill24's Avatar
Mine is tapped on the oil pan as well
Old 08-23-2013, 08:23 AM
spectacle's Avatar
Originally Posted by GrandMasterKhan
my setup:
Journal or BB?
Quick Reply: FullBlown Sidewinder oil return location?
