Full Blown Ford 8.8 Rear End Kits!
Old 12-16-2011, 09:20 AM
  #141
siadam's Avatar
Originally Posted by FullBlown
look for like a 93-94 super coupe. You're really just after the housing. Im sure it is found in earlier or later models, but that is what we've been buying.
What is your reasoning for just those models. I called a few junkyards, and they had regular tbirds/etc but no super coupes. If we are gonna swap out the guts, just wondered what we needed, or if anything else would bolt up that was worth while and wouldn't throw off the mounting hardware, axles bolt up/etc.
Old 12-16-2011, 09:30 AM
  #142
Former Sponsor
FullBlown's Avatar
There seems to be different length housings available for the 8.8 rear diff. We designed our kit around the T-bird one. The problem is some junk yard's computer system will call a match with other applications such as the one from the lincoln.
We now supply spacers in case people run into this problem. As long as it is a 8.8 housing there shouldn't be a problem anymore. So far, out of all the ones that we have built. I have only seen two different variations of the 8.8 housing and you will not be able to tell until you go to mount it on the car.
Old 12-16-2011, 09:59 AM
  #143
siadam's Avatar
Good to know, thanks for the heads up. So with that said, what are our available options for diffs now. What vehicles had 8.8's.
Btw, it might help you, and other future customers if you update all the pertinent information in the first post.
Old 12-16-2011, 11:17 AM
  #144
Former Sponsor
FullBlown's Avatar
We will update this with more info on the diff. If anyone needs spare cases, we usually have them on hand.
Old 04-11-2012, 08:08 PM
  #145
05TurboS2k's Avatar
Its the axles that are of concern. The 8.8 rear is a beast.
Correct it's a beast given it's size. This is the 28spline of course though. Here's what I know as fact as far as the strength of the solid axle version, axles being the weakest link generally.
COT is continuous vs the MOT which is Max
Ford 8.8 28spline COT: 1250 MOT: 4600
These are numbers you can count on as far as the stock setup goes.
I'd like to know what limited slip systems are working well on road courses, I know eaton makes a lot of crap generally in terms of their off-road stuff, it's worthless though my road knowledge of diffs is far more limited.
Old 05-13-2012, 02:50 PM
  #146
bois2k's Avatar
want this so bad need a payment plan
Old 05-13-2012, 03:06 PM
  #147
sata3000's Avatar
Lol I agree. Layaway would be sweet
Sent from my SPH-D710 using Tapatalk 2
Old 05-13-2012, 03:43 PM
  #148
Phill24's Avatar
this would be nice but i think reg saving and self control works too.....(if fbm starts a saving plan im deff down)...lol
Old 05-13-2012, 04:34 PM
  #149
miguel329's Avatar
^lol id be down too...
Old 12-10-2012, 06:06 PM
  #150
WootRWD's Avatar
Absolutely can't wait to get mine installed
Quick Reply: Full Blown Ford 8.8 Rear End Kits!
