Full Blown Ford 8.8 Rear End Kits!
Old 09-11-2011, 04:20 PM
  #131
Former Sponsor
FullBlown's Avatar
look for like a 93-94 super coupe. You're really just after the housing. Im sure it is found in earlier or later models, but that is what we've been buying.
Old 09-11-2011, 05:10 PM
  #132
ghettocrxsi's Avatar
OK sounds good, there are a few in my area I found. Going to rebuild it once I get it. It's too damn hot to go to the junk yard though.
Old 09-16-2011, 04:12 AM
  #133
Importedpower's Avatar
how much is it for the kit (both power ratios) and a rebuilt diff with 3.90's? Also, could you buy the lower one and upgrade to the bigger one? i assume its only the axles that are different
Old 09-30-2011, 12:33 PM
  #134
Former Sponsor
FullBlown's Avatar
We have revised our rear end brackets. The older steel brackets works fine, but we are constantly trying to improve our products. For our customers who have bought the steel version, we are also offering an upgrade. Please contact us for details and the cost.
Old 09-30-2011, 10:01 PM
  #135
tunedbycft's Avatar
You better send me mine!
Fernando @ Kings Performance
Old 09-30-2011, 10:14 PM
  #136
DFWs2k's Avatar
looks like it may be in the lincoln mark 7?
Old 12-14-2011, 05:42 PM
  #137
JoeyBalls's Avatar
Originally Posted by hybridsol
Ok, so I did some searching.... and for NEW it all adds up like:
Stage 3.9 Kit which is rated to 600hp $2695
Ford Racing M-4010-A88 (aluminum) carrier $299 (http://www.jegs.com/i/Ford-Racing/39...oductId=762991)
FORD 8.8" 28 SPLINE REAR DETROIT TRUETRAC POSI 912A562 $470 (http://www.ringpinion.com/ProductDet...and=Eaton_Posi)
(Above is NOT to be confused with Trac Loc which go for $270)
3.9 or 4.11 gearset $140 (ebay)
Installation kit (?) say #120
Total $3724
Assuming any reasonable shop could assemble the diff, how difficult is the install? New wheel bearings needed? Other stuff?
Can we use this DIFF? or is it not compitable for some reason? I was just looking at Diffs, and I see one for $200.00
------8.8 TRACTION-LOK LIMITED SLIP DIFFERENTIALS 28 Spline
8.8" differential Features plate-type clutches Will accept anti-lock exciter ring Requires 4 ounces of CM-19546-A1 friction modifier with initial fill
Can I use this one?
Here is the webpage, look about half way down
http://www.thefordsource.com/store/m...rts/88rear.htm
Old 12-14-2011, 06:13 PM
  #138
Those are the factory trac loc units that come in most mustangs and the lincolns and cobras.
Old 12-15-2011, 06:42 AM
  #139
InductionPerformance's Avatar
This will help meet our goals
Old 12-15-2011, 07:36 AM
  #140
Former Sponsor
FullBlown's Avatar
Total $3724
Can I use this one?
I would spend the extra money and get the eaton posi.
Quick Reply: Full Blown Ford 8.8 Rear End Kits!
