Fule pump wine
Old 03-27-2008, 06:58 PM
btstone84's Avatar
Default Fule pump wine
hey guys, ihave another quick question. I have the upgraded fuel pump that came with my inline pro kit. all of a sudden today i started hearing this constant howling or whining from the rear. Im not sure if its the fuel pump but thats the only thing i can think of. i never heard until today. It does it the second i turn my car on unitl i turn my car off. Is this my fuel pump and is this ok for it to do that??
Thanks
Brandon
Old 03-27-2008, 07:13 PM
Enthralled's Avatar
yes, I'm guessing it is your fuel pump and yes, it's fine.
Old 03-27-2008, 07:15 PM
TRBOKEV's Avatar
Normal for the "winebro" fuel pump.
Old 03-27-2008, 07:19 PM
TelosHedge's Avatar
personally i think it's an added feature.
none of my cars sound 'right' without that whine.
Old 03-27-2008, 07:38 PM
bc02's Avatar
most aftermarket fuel pumps like Walboro's require 14 Volts at the pump to work the way they are designed to by the manufacture(unlike the stocker only needs 12V)....whats happening is the stock wireing leading all the way back to the pump restricts most voltage flow to 11.9-12.0 volts causeing the pump to wine loudly and possibly interfer with other voltage draws like turn signals, headlights....etc.....when the pump gets the proper V needed it quiets down and you can barely hear it at all(also flows more fuel)....your pump will still work good enough at 12V.....but if you want it to shut up....you need to re-wire it running the lead with thicker gague speaker wire directly off the battery all the way back to the pump and tie it in with a 30amp bosch relay....that way when your alternator charges up to 14V when the car is running......your fuel pump will also be getting 14V.....problem solved.
If you don't want to do all that then your just going to have to put up with the wineing and any other electrical interferance it may cause. Most people just don't understand fuel pumps and Voltage flow and bash companys like Walboro who make excellent pumps for the money.
Old 03-27-2008, 10:24 PM
AusS2000's Avatar
Originally Posted by bc02,Mar 28 2008, 01:38 PM
Most people just don't understand fuel pumps and Voltage flow....
Ummm, voltage doesn't flow, current does.
The S2000's wiring is more than adequate for the Walbro 255lph pump.
It's just a noisy pump. You get used to it.
Old 03-28-2008, 04:58 AM
btstone84's Avatar
This morning it didnt even make any noise at all. Does it usually make the noise on and off?
Old 03-28-2008, 06:31 AM
nightcrawler7188's Avatar
mine always makes a loud whine for ~2 seconds when i turn the key to ON. then it stops and doesn't make any more noise. one night the whine kept going, but then it went away
Old 03-28-2008, 06:43 AM
btstone84's Avatar
Mine also makes the noise when i turn the key on, but yesterday it moanned the entire time the car was on. this morining it didnt. i dont know what to think
Old 03-28-2008, 06:51 AM
TRBOKEV's Avatar
It usually happens more after you have been driving for a while. (At least for me) I know on long trips it really wines a lot.
Quick Reply: Fule pump wine
