fuel set up for e85
Old 02-21-2011, 05:03 PM
TurboR's Avatar
Originally Posted by passmans2kny,Feb 21 2011, 05:37 PM
thank you sir, i already have the inline pro fuel rail, with an aem fpr, and 1 of the walbros, sick power u got there, did you build the motor?
Mike Laskey 9.8 short block.
Stock AP2 head with ap1 cams rev it to 9200rpm.
Old 02-21-2011, 05:22 PM
passmans2kny's Avatar
sick car man, thanks for the input
Old 02-21-2011, 06:49 PM
dsddcd's Avatar
Originally Posted by TurboR,Feb 21 2011, 07:31 PM
Dual walbros
ID2000cc
Return & Feeds -8
Inlinepro fuel rail
Fuel lab
Fullblown Hanger
720whp/502tq @32psi on E85, duty cycles was 79%
Thank You for the backup, just to add to this if you do the math and assume a 90% max duty cycle you get the following. This isn't taking account several variables but you are going to be in the ball park.
720WHP/79% * 90% = 820WHP
By the way my new Z gets out of the shop later this week and I am trying to decide on boost / motor options........now. I might just have to stop by and see if I can hang with you later this year before you hit the 1000WHP mark.
Old 02-21-2011, 06:59 PM
s2000442's Avatar
Why is it in the shop? LOL
A 340 aeromotive, 1600cc injectors or the 1300 and a boost a pump should be good for 500-550whp don't you think?
Old 02-21-2011, 07:59 PM
so what would be the ideal compression ratio for e85 under boost?
Old 02-22-2011, 04:13 AM
slappynuts's Avatar
One set up probably costs a little bit more but has far more capability then the other. Reliability is going to favor the setup thats running at a more relaxed pace as well. Running at the very edge of what a fuel system is capable of is very dangerous because when it fails it doesnt just stop it keeps pumping less and less until it leans out the mixture and then you also have an engine failure to deal with.
Old 02-22-2011, 06:31 AM
dsddcd's Avatar
Wetsand and Polish, New Rims and Window tint
I believe you will be good to go with a 1500CC or larger and the 340LPH w/o the boost a pump. I would like to see more details on the flow charateristics of the DW vs the ID's before I make a recomendations.
The factory compression / quench / combustion chambers are nearly impossible to beat.
Old 02-22-2011, 07:05 AM
D1sclaimer's Avatar
Originally Posted by TurboR,Feb 21 2011, 06:31 PM
Dual walbros
ID2000cc
Return & Feeds -8
Inlinepro fuel rail
Fuel lab
Fullblown Hanger
I have the same setup except with an Aeromotive FPR.
Great setup.
Old 02-22-2011, 07:30 AM
11:1 it is then, will the aem fpr suffice?
Old 02-22-2011, 07:38 AM
heres my plan right now, id 2000s, dual walbros(might do dual aeromotive 340s) with the full blown hanger, -8 feed and return, inline pro fuel rail, aem fpr
Quick Reply: fuel set up for e85
