fuel set up for e85
Old 02-20-2011, 02:11 PM
passmans2kny's Avatar
Default fuel set up for e85
would the new aeromotive 340 pump be enough with id1600cc injectors for my fuel needs on e85?, or would I need the dual hanger set up? I wanna break 600, maybe 700hp
Old 02-20-2011, 03:06 PM
dsddcd's Avatar
Dual hanger or two stage pumps. Even with Id2000's a Walbro and BAP at 20v we could not maintain pressure at 550WHP.
Good luck
Old 02-20-2011, 06:52 PM
really? so this was with 1 walbro 255? mabye I'll run dual 340s, that should be more than enough
Old 02-20-2011, 08:08 PM
DFWs2k's Avatar
Does the boost a pump allow for higher fuel pressure though? The aeromotive is supposed to be good for 100 psi
Old 02-20-2011, 11:49 PM
VTECSTYLE's Avatar
From what i was told a single 300-340 should be fine with 1600. MAP was pulling 600 with a single 300 deatchwerks pump and 1500cc.
Old 02-21-2011, 03:40 AM
ok thanks, so a single 340 with a bap might do the trick
Old 02-21-2011, 02:57 PM
dsddcd's Avatar
I would do more research if you are really looking to hit your power goals as you will be buying everything twice.
You are assuming that the 255LPH was not the HP version, note the flow rate drops just as the Aeromotive or DW but is just a bit larger slope.
(2) 255's will outflow your injectors
Not that it is not true but I would be interested in getting the details b/c this is seems to be a stretch.
Old 02-21-2011, 03:18 PM
well thats why I'm asking on here what peoples opinions are b4 i commit to buying anything, when u say outflow my injectors what do you mean? I was planning on the id1600s or the 2000s
Old 02-21-2011, 03:31 PM
TurboR's Avatar
Dual walbros
ID2000cc
Return & Feeds -8
Inlinepro fuel rail
Fuel lab
Fullblown Hanger
720whp/502tq @32psi on E85, duty cycles was 79%
Old 02-21-2011, 04:37 PM
thank you sir, i already have the inline pro fuel rail, with an aem fpr, and 1 of the walbros, sick power u got there, did you build the motor?
Quick Reply: fuel set up for e85
