Fuel Return Options
#24
Yes exactly this. It sounds more daunting than it truly is, their PDF instructions and customer service are great, I changed a few things in regards to mounting positions for the breaker and relay, but zero issues otherwise, and steady fuel pressure at all times now.
#26
What do you guys think of the Seamless dual pump wiring kit instead of wiring it myself? I was thinking about going this route with mine since I have the CJM dual hanger and twin 535 pumps. You also get a choice of going with the "Wire loom- Raychem DR-25", but I'm not sure if that is worth the nearly $100 addition. Anyone know if that is worth getting?
I'm also trying to figure out whether to have the pumps staged to come on separately or just let them both run all the time. Seamless offers either choice and not sure which would be best.
Any help?
Any help?
#27
Any help?
Any help?
As for staged or running them together, I have no experience on that but would be worried about the alternator supplying enough voltage at idle/low load.
Spoolin (03-19-2024)
#28
Here is a picture of the line under the car:
This is with the -6, an 8 might fit but I could see a 10 being to big. That said he obviously has the jig so could fab up something for you however you want.
#30
