Fuel rails with nitrous port?
Hey everyone,
Im looking to go wet nitrous and im wondering if thres a fuel rail out there that has an aux port that i can use for the fuel feed on a wet nitrous system.
any ideas or products that have that?
everything is going to be stock (stock injectors, pump ect) this is going to be for 50 shot and under
No, you could buy a rail from Inline Pro if you want a spare port but you need to think about what you are trying to do a bit more.
The only scenario that would make any sense would be to take excess fuel out of the rail then feed it into the fuel solenoid on the Nitrous kit.
That however would be a huge waste, the stock fuel line is rubber and can be easily spliced to get your fuel. Or you can easily drill and tap the rail with an extra port.
mostly i dont like to do that if i can avoid it. cutting into fuel lines sucks. plus i did it last time with my other nitrous setup and didnt really like how...messy it looks
Originally Posted by directportjuicedS2k,Jun 12 2009, 03:11 PM
I really dont think tapping the fuel line is bad at all, just tap it on the rubber line like 1.5 down from the fuel rail, you cant see a thing.
(1) 14 x 1.5 Flare to -6 AN at the bottom
(1) Banjo Bolt with -6an Adapter
http://www.034motorsport.com/index.php?cPath=40_52
Originally Posted by dsddcd,Jun 12 2009, 05:32 PM
Better yet make your own fuel line
