Fuel pump WONT STOP PRIMING
Originally Posted by camuman,Sep 15 2010, 11:37 AM
didnt u rewire the pump when you were turbo? might be shorting out. i would trace all that wiring first.
So i wired the trigger wire for the fuel pump up to my 12v accessory socket, guess i can't do that because now it won't stop priming.
I hooked it back up completely stock and am reseting the ECU right now.
FIXED!
So as i was taking my spark plugs out to run compression test, i hear the pulsation dampener begin to pulsate. Out of no where the fuel pump is priming fine now.
Every since going back to N/A after FI my car has been acting insane. Wipers would not shut off at all the other day. ECU must be having seizures.
