Fuel pressure 85psi at idle?
Today I noticed that my fuel pressure was at 85psi at idle, is this normal? If i remember correctly when I first installed my comptech S/C fuel press. was at 50-60psi at idle. Everything seems fine but the high fuel pressure kind of scares me. Is it ok to drive?
at idle, 80 deg. outside
If the gauge is right I don't beleive that factory injectors will stand that kind of pressure for long. Some one correct me if I am wrong.
it will run, really rich at that, until one of the injectors fails.
What I need to do is get this thing to a dyno and figure out why the fuel pressure is high, This could not be from having a testpipe and an exhaust could it? I know it the TP and exhaust can effect richness/leaness but fuel pressure? I doubt it.
Or I use someone else's gauge to make sure its reading correctly.
Ok well I tapped the gauge a couple of times when the engine was off, the needle moved slightly, started the car and it read this:
It has to be the gauge, unless somehow the fuel pressure can jump 20psi in 10 mins. without messing with anything except for tapping on the gauge.
why ASAP? Is there a danger to me if I drive 100 miles with a defective gauge? I plan on getting a new one the end of this week.
The car is stock except for the s/c testpipe and exhaust
I have RC 750cc injectors, a wahlbro 255 lph pump and an AEM FPR(a 1:1 regulator). My idle pressure is set to about 47-48 psi with the vacuum line connected and with a blip of the throttle, it jumps to around 56-57 psi. Does this seem about right for my setup?
Not to scare you any but I would replace the gauge ASAP.
Go to autozone and get a cheep one for now.
If you look at the gauge and it starts to "pinwheel" better shut off the car right away. When a Gauge starts to pinwheel it is a sure sign the gauge is about to rupture.
I have only seen this pinwheel effect on very high pressure lines (10K-60K) those gauges do not have nettle stops on them for this exact reason.
It looks like yours has a needle stop so If you ever see the nettle pegged on the bottom of the stop (fully loped around) I would not trust it to hold under any pressure.
In this case if there was a rupture it most likely would come from the middle of the needle attachment and fill the gauge face with fuel with a possibility of fuel pushing out though the gauge face cover causing a very hazardous condition.
In the case of the high pressure Gauges pin-wheeling the gauge literally explodes.
