fuel line
Old 05-27-2006, 08:59 AM
bs-inc.s2k's Avatar
Default fuel line
how long of a line will i need? for those with stock fuel rail, what size did you go with?
Old 05-27-2006, 09:04 AM
04RioS2k's Avatar
wow can you get any more specific then that? I mean the amount of information you just posted is just wayyyy too much.....
Old 05-27-2006, 11:48 AM
bs-inc.s2k's Avatar
fuel line length. fitting size.
Old 05-27-2006, 12:07 PM
WLAURENT's Avatar
The fuel line from the fuel rail to the point where it connects to the steel line under the car coming from the tank is a unique piece. Pretty sure dealership or online honda parts place is the only place to get it.
Perhaps you may start by telling us why you need a new line, or what you are doing that requires that you replace the current one.
Old 05-27-2006, 12:23 PM
markS2kcU's Avatar
I had to change the return fuel line from the Comptech FPR back to the under car metal pipes, I used 7.6mm ID got about a meter of it and cut it to size.
Old 05-28-2006, 05:01 AM
fperra's Avatar
If you expect to get usefull answers you need to provide more information. Since you are posting in the FI forum I assume you are planning to SC or TC. What horsepower are you planning to build for? The stock fuel line and rail is good for at least 600 whp. The only thing in the fuel system that needs upgrading is the fuel pump. If you are planning for more than 600 whp, you should have enough knowledge about cars and wrench turning that you shouldn't need to ask the question.
Old 05-29-2006, 12:43 AM
bs-inc.s2k's Avatar
i was just wanting to know the length. yes i'm going FI... all i needed to know was the length. fitting will be -8 -10. i'm going to retap the fuel rail. thanx for the help.
Old 05-29-2006, 06:41 AM
MB
Member
MB's Avatar
How come Mark?
MB
Old 05-29-2006, 11:03 AM
markS2kcU's Avatar
Originally Posted by Dark Blue Mark,May 29 2006, 03:41 PM
How come Mark?
MB
Why? on our right hand drive cars we have to put the FPR somewhere else, and where I put mine the return pipe wasn't long enough.
That was the only spare place I could find to bolt it.
Old 05-29-2006, 11:10 AM
MB
Member
MB's Avatar
Ah I get you. That's where I had mine too!
MB
Quick Reply: fuel line
