Found the limits of the stock clutch
Old 08-04-2006, 07:48 AM
gotswap's Avatar
Default Found the limits of the stock clutch
So my stock clutch was good until about 350whp and then started slipping on the dyno. I know that the ACT pressure plate and stock disk seem to be quite popular on here but will it hold in the 350+ range?
I have been looking at the Exedy hyper single and Clutch Master stg 3 segmented kevlar clutch with a Spoon flywheel as alternatives. I had the CM before and I really liked it, just not sure it is up to the task.
What are the 350+ whp guys and gals running? I want something that will hold the power and do not mind a bit harsher engagement. I would also like to stay below $2000 are there any other options?
Thanks!
Old 08-04-2006, 08:25 AM
John_Z's Avatar
I'll soon be past the 350 mark and I'm running the HTG package. I know a fella running 450 plus and another at 370 using this same package
Old 08-04-2006, 09:11 AM
S2000_Europe's Avatar
I had 320 whp and was runing with the stock clutch without problems. Since I have a stock differential, I prefer a slippry clutch than a broken diff.
If you go with a stongre clucth remember that your next weak point is the diff.
Old 08-04-2006, 10:05 AM
j_c_a's Avatar
My HTG package is holding fine at 400+.
Old 08-04-2006, 10:08 AM
kane.s2k's Avatar
Competition Clutches Stage 3:
http://automotivespeed.com/product_info.ph...products_id=141
Old 08-04-2006, 10:38 AM
OGPackin's Avatar
Originally Posted by kane.s2k,Aug 4 2006, 01:08 PM
I just picked up Competition Clutches IronMan from AS. Im getting my car back tonight. I will LUK how i like it....
Old 08-04-2006, 10:39 AM
gotswap's Avatar
Originally Posted by kane.s2k,Aug 4 2006, 11:08 AM
I was looking at that one as well. Looks just like the Clutchmasters. Are you running it? How much WHP?
Old 08-04-2006, 10:41 AM
gotswap's Avatar
Not to worried about breaking stuff, I don't really launch the car and I run ~3.5psi daily. Just need it for the "just in case" scenario. You never know when you will run into a fast car that is begging for a whooping
Old 08-04-2006, 10:42 AM
Old 08-04-2006, 01:09 PM
Spoolin's Avatar
Spec Stage 3 clutch is awesome. It will hold at least 400 lbft of tq but they claim 492. $577 at MVPmotorsports.com
Quick Reply: Found the limits of the stock clutch
