Flywheel question for SOS SC
Hey,
I wanted to ask you guys a question and see what you think.
Can i use AP2 flywheel with ACT clutch on my SOS supercharger. Seems like i do not have Pilot Bearing for ap1 flywheel. Is there is issue if i use ap2 flywheel ?
Secondly, can i get the ap1 Pilot bearing for flywheel from a Honda Dealership or any other vendor.
Any help will be appreciated.
Thank you
Thank you
While I don't have the knowledge to properly answer your question, I went with an AP1 flywheel (which is much lighter) with my SOS II setup. I just found an AP1 flywheel and got it resurfaced and swapped in. My installer didn't mention I needed a pilot bearing for this swap. Maybe the AP1 and AP2 ones are interchangeable? Someone with some more knowledge will surely chime in. When I was doing my research, I found that this with the ACT pressure plate would be best in terms of cost and performance.
psychoazn
06-18-2008 05:26 PM
