Flushing Vortech Aftercooler with Spearco Rad
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Well previous owner put a 50/50 mix of anti-freeze and water. i want to flush it out and put water w/ redline water wetter. How would I go about the flush? Car has the Tech2 Spearco radiator setup.
Should I also flush the car's radiator? I am in SoCal so I dont have to worry about the weather.
Thanks
Thanks
Water wetter with water has great cooling properties. Not having to worry about freezing is another plus. Flush it a few times with distilled water if you really want to clean it out. The only thing I'm unsure of is if the water wetter has anti-corrosion properties. Then again it's just going through a radiator, the aftercooler, and a pump, so there is really no harm done without corrosion protection. I'd say go for it.
There is no actual drain. Just pull off a low hose, one that goes into the bottom of the radiator piece or the pump. The pump should be mounted at the lowest point in the system. This won't drain every bit of antifreeze. If you want to complely flush it, do this a few times after topping off with water and running the pump (turn the car on).
Water wetter does contain corrosion inhibitors though I run antifreeze personally (I'm in PA).
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
Originally Posted by 9kFever,May 18 2008, 08:18 PM
will purified water work or do I absolutely need distilled?
i understand how water wetter would help lower temp for the coolant in the engine, but i dont know about the aftercooler. Im just thinking, the water wetter reduces the surface tension of water and in turn the size of the bubble formed in the water. This increases surface area of the water on the surface it supposed to be cooling. Does it get hot enough in the aftercooler to create these bubbles and constitute a need for water wetter?
any before and after testimonials or temperture tests on intake temp?
