Finally happend, something BLEW :(
you think the egt's cooked the turbo? The turbo is made to be glowing red hot...so hot you could have a small cookout with brats on the turbine housing. I dont think EGT's cooked the turbo....maybe the seal on the turbine just needs to be replaced...but turbos dont "cook"...lol
Originally Posted by devs2k,Mar 13 2009, 01:00 PM
it's not really an issue with the greddy turbo itself...rather, it was the very high EGTs from running on stock compression.. the EGTs cook the turbo..
call greddy and tell them you only have 15k on the turbo... see what they have to say..
Ok, I am moderately retarded, the car i fine it was an abnormal amount of condensation, also as far as the EGT go with METHANOL they have to be much lower, the intake manifod is cold aftr WOT, aain, I am retarded
Glad to hear she's alright...FYI, Billowing white smoke is typically an indicator of a blown head gasket and lots of blue smoke under load is more an indicator of a turbo that going. Take off your oil cap and dip your finger in there. If the oil doesn't appear milky then you're likely ok...not likely a blown HG.
