Finally a Greddy turbo AP1 1/4 mile pass
Old 07-11-2008, 07:50 AM
Revenge's Avatar
Good times, it's not easy launching the S2000 with out breaking stuff, I think you did it the right way. The goal is to have fun but don't bust up too much stuff.
Old 07-11-2008, 08:30 AM
JoeyBalls's Avatar
I noticed that the OIL FILTER gets super super hot so I put some heat Tape just on the one side where it is an inch from the charge pipe, I covered only a small amount of the Filter becuase I know that needs to cool down as well, but I also put some heat tape on the charge pipe where it faces the oil filter. My car runs like asshole when its hot/heatsoaked, and runs like a fukin beats when its cooler out. Lats night it was 65 degrees outside and the car was spinning through most of first........
I am going to go to the track here in Old Bridge, but am going to do so on a cold fall night............
Old 07-11-2008, 02:40 PM
S2SEXY's Avatar
is your car tuned?
Old 07-11-2008, 02:46 PM
RacerXI's Avatar
Is the OP's car tuned? 10.X AFR's are rich.
Old 07-11-2008, 03:55 PM
S2SEXY's Avatar
actually best bet might be tuning up the boost 1 psi and see if it will lean the car out to a better a/f ratio
Old 07-11-2008, 04:49 PM
SgtB's Avatar
Nope.
Old 07-11-2008, 06:28 PM
S2SEXY's Avatar
^ explain
Old 07-11-2008, 07:05 PM
Rxmfn7's Avatar
I dont mean to badmouth anything and I hope I dont offend, but a 100MPH trap speed is ungodly pathetic. Im hoping something is severely wrong with your car or the tune is extremely far off. I didnt buy the greddy kit to have a "fast" car, but if I only trap 100MPH Ill drive the car straight into a wall.
Old 07-11-2008, 07:09 PM
S2SEXY's Avatar
he said it was very hot,i ran the same times with just a intake and exhaust on a cool day though
Old 07-11-2008, 07:12 PM
Rxmfn7's Avatar
Hot or not, should still be pulling much better traps than that. 300WHP when tuned, I could see it losing 20-30whp due to the heat, but going even further say he is only making 250WHP, that still should be a ~105-108MPH trap. As you said, a light bolt-on N/A car can trap 100mph no problem. I trapped 97 compltely stock on my 1st and only run with this car, with a slight mis-shift to 2nd.
Quick Reply: Finally a Greddy turbo AP1 1/4 mile pass
