FBM / Avid racing Billet Motor Mounts
#241
Originally Posted by timg' timestamp='1339938647' post='21788289
I am too. I ordered them last week. My stock motor mounts are completely shot and I didn't want to deal with all of the issues poly mounts seem to bring (melting, sagging, crazy vibration, etc.).
Tim
Tim
Tim
#242
My new HASport mounts came in - 70A
Billet pieces are large and beefy (you can feel the weight). Note how large the urethane is in diameter.
Brackets included in kit
The subframe studs are bolts which go from the bottom's up. Here's a comparison next to the Avid mounts
HASport bolts are 55mm in length, washer is 2.5mm giving an effective stud length of 52.5mm. This is about 15mm of thread engagement (vs 6mm from Avid). That's more like it
#244
I just installed my Hasports about 1/2 hour ago....Here are the pictures.
Since I am runnting the PTuning kit, the Passenger side OEM motor mount gets replaced as part of the Turbo Kit. Hasport is nice enough to sell you only the Drivers Side.
The PTuning Replacement Mount comes with a 60A Hardness.
I ordered the Hasport in the 62A which is a very close match to the PTuning replacement
There is almost NO Noticeable Added Vibration....over and above the initial added vibration that was a result of the PTuning Passenger Side Replacement Mount already installed.
Did however have to "Cut-Out" a small piece of the mounting bracket to clear part of the Engine Block. It looks as if the Hasport guys knew this due to one of the plates on the mounting bracket was already "Cut-Out"....but it's like they forgot to finish it off all the way through. (See Picture #1 Below)
All in All...Very Happy So Far..!
