FBM / Avid racing Billet Motor Mounts
#192
The new nuts and studs are finally in my hands. Some pictures for reference
New studs are ~12mm longer
Old stud
New stud looks much much better
Here are the new nuts Avid supplied to workaround the short subframe studs
Note, after installing & removing the nut, it will take the black coating away from the studs
Overall these mounts are moving in the right direction. I'm looking forward to the Final version where the subframe studs are corrected & lengthened.
Avid/Franklin,
When will the new brackets with longer studs become available?
Old stud
Avid/Franklin,
#194
Do you know if it's possible to just order one? I Only need the Drivers Side.........The PTuning kit revises / relocates a special kit made mount for the passenger side du to the turbo placement?
The OEM mount on the drivers side $hit the bed last week.....looks about like the picture from page #1 of this thread.
AND....Has Avid fixed ALL of the stud-length / slop / bracket / fitment issues yet?
FB let me know. Thanks
#195
Sent using free Tapatalk - Android FTW
#198
Issue #1 - Brackets were too wide and had slop between it and the poly mounts. New brackets (version 3) have corrected the width issue and has added 2 washers per side.
Issue #2 - Studs protruding from the top of the Avid mount to OEM mount bracket were too short. Avid has corrected this by providing new studs which are 12mm longer and fit the OEM bracket properly.
Issue #3 - Studs protruding from the bottom of the Avid bracket going thru the front subframe are too short (only have 6mm thread engagement). Short term corrective action was to provide slim nuts which will bite the 6mm thread that is exposed. Per Post #190 from Avid, all new mounts will have the corrected stud length as well. Franklin from Avid states "However to satisfy anyone the next batch we'll make sure that the studs are longer and include a nylon standard lock nut instead. "
I am looking forward to receive the new mounts with all the corrections in place.
#200
So then.....do you guys feel that it's safe to go ahead and place an order...?
With the expectation that when the product shows up at the front door....the above mentioned issues will have been addressed and properly corrected?
An official AVID reply here would be greatly appreciated.......
