Extremely lean idle, possible misfire.
Old 02-03-2013, 11:44 PM
Manny2587's Avatar
I think this issue may also have something to do with o2 sensor feedback as well. Was your friend using closed loop operation? I read that you are not using any factory o2 sensors and only the aftermarket wideband. Is the wideband set up for closed loop feedback?
Sent from my iPhone using Tapatalk
helloimsteve's Avatar
Thanks! Difference here is my bud had an SOS 3 bar. I have a Homdata 4 bar. Assuming that's why I'm leaning out cause the fuel is trimmed for a 3 bar map sensor, yeah?
Old 02-04-2013, 04:20 AM
Manny2587's Avatar
Yea that's definitely a reason you could be having this issue
Old 02-04-2013, 05:40 AM
From my understanding, the fuel delivery should be the same, but the MAP Calibration would have to be scaled for a 4 bar. Is that correct?
Old 02-04-2013, 10:14 AM
Pulled a log and pulled the map if anyone can take a look at it. Changed the MAP values and had the same result. I'm only idling the car for 5-6 minutes, not full on driving.
Will post them as soon as my Mac is done updating lol.
Old 02-04-2013, 11:34 AM
Here are the maps. If anyone can identify the problem, please post it! My set up is as follows:
InlinePro Stage 1, Precision 6265, InlinePro BOV, Tial Wastegate (7 lb spring), stock exhaust, ID 1000's, Aeromotive 340 LPH Pump, Hondata 4 Bar, AEM EMS V1.
Map 1 - Adjusted the MAP Sensor
https://docs.google.com/file/d/0B52P...lfNUotNWs/edit
Map 2 - Map that came with the tune
https://docs.google.com/file/d/0B52P...pZR0RfUXc/edit
Log 1 - Log when it sputters
https://docs.google.com/file/d/0B52P...dwblFSckk/edit
Old 02-04-2013, 08:02 PM
Anyone?
Old 02-06-2013, 04:10 AM
s2kt3's Avatar
I found when I had the aem v1 and the hondata 4 bar i could not get the map values to read correctly, when the car was off the map value would read like 8 in/hg which is way off should read close to 0.0, I wasnt going high boost when I started so I threw the honda stock map back in, re calibrated the map values and it read correctly.
and the car ran great !
-Lee
solitarycheese
05-12-2014 08:36 AM
modMonkey
07-09-2013 02:00 AM
tndds
07-25-2012 08:17 PM
Black Nugget
09-29-2010 01:57 PM
Competitor9
09-21-2010 09:00 AM
Quick Reply: Extremely lean idle, possible misfire.
