Enough for E85?
Enough for E85?
I have the following for my fuel system, but I'm not sure if it's enough to run E85.
DW300 fuel pump
FIC 900 (1000cc) injectors
Should I get a rail and FPR, and maybe larger injectors? Do I need to upgrade the stock lines?
DW300 fuel pump
You are going to need bigger injectors if you do not raise your base fuel pressure. I started to run out of fuel with one aeromotive pump on 1600 ID's at 544whp at 18psi E85. You can get close to 500whp on your current setup. You dont need a rail and your stock lines are fine for that power level.
riceball777
09-21-2011 10:00 AM
