engine light keeps coming on
Old 12-01-2005, 11:03 PM
red01's Avatar
Default engine light keeps coming on
hey guys whats up? me again with another quick question. A while back I wa having a problem with my boost levels with my super charger and long story short got it fixed but now when I get up to 6500 once again the engine cuts out and the engine light comes on. any Ideas why this might be happening? muchly aprecieated if anybody has any input. Thanks
Old 12-02-2005, 12:26 AM
Trip's Avatar
the best way is identify the fault is read the error code using a OBD scanner.
Old 12-02-2005, 04:46 PM
folex187's Avatar
Without giving a code you're not going to get the right answer...
Old 12-03-2005, 12:29 PM
savs2k's Avatar
what exactly did they "fix"? just use a obd2 scanner to see what code it threw
Old 12-03-2005, 11:13 PM
red01's Avatar
it gave back a code of 2640 I think I will find out exactly for sure on monday but regardless it said that it was a unidentified code
Old 12-03-2005, 11:20 PM
folex187's Avatar
P2640 isn't listed under the trouble codes that I have. It goes from P2631 to P2646.
Old 12-04-2005, 07:08 AM
MrHonda's Avatar
Check your oil level. You may be getting a VTEC code due to lack of oil pressure at the VTEC pressure switch.
Old 12-04-2005, 07:12 AM
MrHonda's Avatar
I forgot to mention that this applies to Codes P125x (p1253,P1257, etc.)
Old 12-05-2005, 09:49 AM
red01's Avatar
It comes back as a code 2642 does that sound familiar to anybody?
Old 12-05-2005, 01:39 PM
folex187's Avatar
Maybe your scan tool is messed up? It should read Pxxxx. P2642 isn't listed either. What are you using to pull the code?
Quick Reply: engine light keeps coming on
