Engine Build - Stock Block-Sleeved-FRP Pistons....
So I have been talking with several people on the boards and can't seems to come to a consensus. Just in case I ever pop my motor I have been trying to get plans in place so that I can quickly get a new one back in the car without spending weeks or months trying to figure what I am going to replace with.
Option 1 - Spend $2,800 on a new 2.2 short block from Honda
This is my number one option b/c I will know that everything is perfect and I can just bolt on the head and call it a day.
Option 2 - Buy a used short block with good cylinders and have a machine shop refresh it.
Problem is I do not know any quality shops that can balance, hone, line hone..... Locally so I would have to send it to ??????? Anyone have a good machinist that can work on it.
Option 3 - Same as Option 2 but with Wossner FRP compliant low compressor pistons
I have still not seen anyone that has been running these long enough to tell if they will hold up and I know there is controversy about if they are really FRP compliant.
https://www.s2ki.com/forums/index.php?showt...&#entry17313790
Option 4 - Same as Option 3 but with machined factory pistons to lower the compression.
Again I am waiting to see how this option holds up on Artisan7471's car
https://www.s2ki.com/forums/index.ph...f=142&t=732173
Option 5 - Have the block bored and sleeved, use new rods, pistons.......
I worry as I have heard many members have had issues with sleeved blocks
Isn't Momentum trying to get Mahle to make some low-compression pistons specifically for the F20/22? The H22 pistons (-7cc dish-style) have the crown that is 1mm or so too tall for our engines, so it would have to be machined still..
I think you know where I stand on this one, lol. For less than $200 you can go low compression, however it's a but load of work to remove your pistons for mahcining.
Originally Posted by ya@inlinepro,Apr 9 2010, 11:56 AM
Scot,
You should always re hone it, so the clearances are proper to the pistons whether the sleeves are in good shape or not.
If I were to rebuild I would have the block honed, the mains line bored, the rotating assembly balanced, block decked........... all the normal stuff.
So, that being said would you recomend rods? I see alot of people buying them but I don't know that I have seen anyone break a rod with the small amount of power I will be shooting for.
