EMS location
EMS location
I just recieved my AEM EMS and will be having it installed soon. Where have some of you mounted the unit? Are there pros and cons for different locations or is it a matter of preference ? Is an extention harness needed to mount behind the seat ? If so does the FROG 5' harness reach ? I appreciate your help .
If you have the 1052 you can mount it in the stock location with the velcro strips they supply. If you have the older version you'll need the Frog harness to extend the wires. the 5' should definitely be long enough for you to mount the EMS behind your seat.
I'll answer this because everyone's learning curve has to start somewhere but please read the plethora of information available here.
The AEM EMS is a standalone engine management system. It completely replaces the stock ECU.
Originally Posted by Chiung,Mar 29 2007, 08:47 PM
