Electronic Boost Controller Question...
Hey guys, I just picked up a Profec E-01 and I want to install the boost controller tomorrow, but I know that I won't be able to dial it in until I bring it back to the dyno for another tune. So my question is if I would be able to hook up the boost controller with re-routing the vac lines from the turbo and the wastegate, and hook them up to the new solenoid/controller, and if I turn off the controller will the car still run off the wastegate spring? Any insight would be appreciated. Thanks.
Originally Posted by AROD,Sep 19 2006, 09:16 PM
yes it will still work off the wastegate spring
Originally Posted by XclusiveAutosports,Sep 19 2006, 10:18 PM
Good to know, thanks again for hooking me up. I'll slap this bitch on tomorrow.
I am sure it's a good unit for controlling boost but i could not get the damn thing to work. Even after calling profec, which by the way they do not even have a clue how to even do it. Either that or I spoke to some schmuks.
I would honestly recommend a manual unit. when I tried what they said my boost curve was all over the place, did not even make sense at all.
But good luck regardless.
PS. I am only using it to datalog as I connected my wideband to it.
Originally Posted by Kwando,Sep 19 2006, 09:43 PM
i see you are using EMS why not just get a GM boost solenoid? just curious.
Originally Posted by Venomous S,Sep 19 2006, 09:40 PM
hmmm, u shold've asked me first
^ Thanks bro. I'm going to install it now. If the controller doesn't work out then i'll just uninstall it and go with a manual setup. I was just looking for something that can allow me to change between low/high boost on the fly so I can use the tune I have now for daily driving and then have a tune for 8 or 9psi for the hell of it.
