Electric Boost gauge Sending Unit
I have the Nordskog digital boost gauge and the sending unit is supposed to thread into the intake manifold. Not sure I want to mount this thing in my intake manifold or where I would even do that.
For those of you with the electric boost sending units where and how did you mount your sending unit. And suggestions, pictures, or personal ideas would be much help!
Thanks
Thanks
You need to find out what kind of threads are on the sender, them look for a fitting that has a female threaded end and a hose barb on the other. Most likely it's 1/8 NPT. Run a hose to any intake manifold vacuum source to the sendor. You'll have to T into an existing vacuum line, the FPR line works. You can also splice the vacuum line to the air pump control solenoid.
It's either that or drill a hole in the intake manifold and tap it for the needed threads.
