EGR Block Off Plate & Ports
So I posted this in my build but was wondering if anyone else has done this?
From what I can tell the exhaust travels from the exhaust port, down the side of the head then though the head at the back and around into intake manifold. If there is no EGR/ACV valve the exhaust would be able to travel back into the intake causing contamination (See S2kPuddyDad Post Below).
Basiclly I just used a 1/4" x 20 tap and then threaded in the small St-Stl set screws. I did not tap all the way to the exhaust port so it can't get to the exhaust port and by reinstalling the EGR plate they can't back out either.
https://www.s2ki.com/forums/index.ph...c=550727&st=25
there is no way for the exhaust to get back into the intake, considering the EGR valve (and only pushes air under pressure into the head) does not get its air from the intake plenum, but from the air pump, and then the air filter.
Originally Posted by 03silver2000,Apr 13 2009, 07:17 PM
hmmm interesting...that head looks amazing though!
