E85 cons?
Old 10-13-2014, 10:26 AM
lude92_si's Avatar
Originally Posted by fvkyeahAP2
how do i go about doin that? I was told to do so as well. you have a link on how it works or the installation? and is there a kit for it?
http://www.scienceofspeed.com/produc.../E85_FlexFuel/
is there anything else i need? change of fuel tank? or....
I'm just running a GM flex fuel sensor and harness. With a walbro 450 e85 pump and using a AEM v2. And id2000s.AEM fpr.
Old 10-13-2014, 03:50 PM
yamahaSHO's Avatar
Originally Posted by d-bo
Originally Posted by yamahaSHO' timestamp='1413214869' post='23367497
[quote name='d-bo' timestamp='1413211026' post='23367423']
Cons to E85 -none
Unless you're trying to drive your car when it's 40* out and you left it sitting outside for 2 days.
^That shouldn't be a problem if the tune was done well.
If you have a standard full size battery you might be ok. I have a different car than you guys so it's a little different. On mine a different tooth crank trigger plate helps when running aem to start better. I've started mine fine when it's been 45 but my PC680 has horrible cold crank so if it's sat for a week of coldness it sucks
E85 is probably the best thing there is if you want to make over 400 hp with no worries. If you don't just run 93
I let my evo sit from October-April last year and it was fine. Started right up and had no problems.
My fuel filter in the pump assembly got shitted up tho. I have removed it and now run a fuelab filter. Not sure about s2k
If you store it for winter I would put some 93 in it and run it for a while. The regular gasoline will clear out the lines and other fuel parts.
[/quote]
I have a little battery as well...
Old 10-13-2014, 05:09 PM
Spoolin's Avatar
If storing your car for a while with e85 filled to the top of the tank and running ID injectors, just pull the injectors and pickle them. To do this you only need to hook a 9 volt battery to the terminals, which will open the injectors and then spray WD40 through them and disconnect the battery. You'll be set for the next time you're ready to run and won't have any rusting issues. This is how a tech at ID told me to do it BTW. You can also put some e85 stabilizer in the tank to control moisture.
Old 10-14-2014, 01:14 PM
Phill24's Avatar
or just run some 93 in it..no need to pull injectors if ur going to store the car for the winter
Old 10-14-2014, 02:02 PM
06S2k07Si's Avatar
Can one just run stabilizer through and call it a day for sitting through the winter from say November to April? ...and expect to have no issues?
TonysMI4
08-28-2011 11:21 AM
joefish1298
07-21-2010 06:15 AM
siadam
04-25-2009 06:53 PM
Ink01
07-23-2006 08:19 AM
CrazyPhuD
07-06-2006 03:53 PM
Quick Reply: E85 cons?
