Dual wastegate boost control solenoid hose routing
#22
How do you expect it to work if you cant even activate it? It doesn't matter how you have the vacuum lines hooked up if you cant activate the solenoid via infinity tuner. There are various tables that play a part in the solenoids activation under the boost tab. Learn the software or take it to someone who does know it.
And no, you do not have the 3 port hooked up correctly. You have the boost reference going into the bleed port.
#25
#26
the middle forward facing port on the 3 port is a vent and should not be used and they make a small brass filter that should be used there.
DanielZan
04-19-2019 05:50 PM
aserr
Cars for Sale
04-13-2019 09:14 PM
rjh234
47
02-06-2018 08:37 AM
