Do you have to sleeve the block when running forged pistons and rods?
Do you have to sleeve the block when running after market forged piston such as je/wiseco/cp/arias?
Yes. The factory block has FRM (Fiber Reinforced Metal) Sleeves that can only be used with FRM compatible pistons. You must put new sleeves to run aftermarket pistons.
Does anyone run these pistons on the stock sleeves? How about running these pistons with the stock rods ?
I just want to make more power on straight 91 octane. Right now I'm just under 400whp on 91 octane at 11 psi of boost.
I figure with a 9:1 compression motor I can boost a out 20psi on straight 91 octane and make about 450-500whp
PeanutButter
09-18-2007 05:28 AM
