Do I need High grade bolts?
I have a vband adapter for the hotside for my turbo. The current grade 10 allen bolts i am using wont let my vband clamp down because the heads on the bolts are too big. I was planning to get bolts with a smaller/thinner head on it and use nordlock washers to hold them in place. Does it matter what kind of grade bolts I use or do I have to use special ones to withstand the heat? I will have the hot side wrapped in ATP wrap also before it goes on. Just wondering if I can go to homedepot and get the thread pitch I need and bolt.
ill try taking some. So I have a 6 bolt flange that has a vband welded onto it. The bolts holding the downpipe adapter on hits the vband clamp because it wasn't welded far away enough so I need bolts with smaller head on them to fit.
I would tap the holes and bolt from the back...can't believe someone made something that tight!
Yeah that's what I would do. Have them counter sink it a 1/4"-3/8" in deep so it goes in enough to clear the clamp. The good news is you won't have to worry about your bolts backing out and losing them
