Do I need to calibrate my gauge ?
Just wired my white wire from my aem afr gauge to pin c16 on the ecu harness.
Just wondering if I need to calibrate the gauge or do anything else ? Getting ready for an Evans etune.
And there is a process I getting the ems to read the gauge correctly. Read the online manual for the afr gauge on the AEM forums, it has a few things you have to set. If you can't find it, send me your email and I'll get it to you.
you will have to adjust your o2 sensor gain on the aem ems to get it to read close to what the wideband is already reading. youll see that if you adjust in one derection it will say your way lean and if you move it the other way it will get closer untill u pass it and it will read richer. you'll have to find the sweet spot to get it right.
If you really want to run calibrations usually the MAP needs it more than anything else. Additionally AEM had the wrong curves in for the Air and Water temperature sensors. It is not a huge difference but that is easy to input.
