difference between aem ems 1012 and 1052
1012 is the older model. some people have had problems with the cranking. the 1052 is the newer model which seemed to have fixed the problem. there is also the 1052U which has built in wideband
1052 is also in a smaller case. There are also changes to the input and output assignments- a map from one will not work in the other.
Tim
Tim
