CTSC fuel injectors
CTSC fuel injectors
im planning to get some 680cc injectors local off of an srt4 can i run these will they fit? Are fuel injectors fuel injectors? i know i need the clips and harness for them but anything else? Im planning to do 10-12 psi will these injectors be to big? Or can i use some type of emanage to take away fuel? better to be to big than to small right?
How many CFMs will your CTSC be pushing @ 12 psi and how many lph can those fuel injectors push at say 75-85% duty? Figure that out and see if they are too much.
Also, freshs2k your car is confused as to if it is black or white, please help it out by painting.
they are cryo'ed so it might take awhile or ill run all the teeth off the gears with a few hard launches and some hard shifts with this 6 puck sprung act clutch.
