Constant leaking through oil inlet
I currently running GTR35R with -4 oil rescrictor inlet, it keeps leaking through the an fitting, we have swapped out the an fitting for a new one and same issue. can't seem to figure out what is causing the leak.
I have been lucky so far as nothing has caught on fire. but that is something i do not want to deal with
any help is much appreciated
OP can you just thread the fitting straight into the turbo in stead of using the adapter plate? Thats what I did when my gasket started to leak.
Thanks for the tips guys.
right now it goes turbo-oil restrictor- an fitting to oil feed line. sadly have to wait till tomorrow but going to end up re doing the whole oil feed system and hope it solves the problem
stack
08-21-2009 05:26 PM
