comptech supercharger pulley
The person that installed my supercharger pulley put it backwards.....................
What tool may i use to remove without damaging the pulley???? i have tried two already from autozone and nothing...
Neat
Use a belt wrench. Its the best way to go I have found. Make sure you clock the pulley to where the keyway is on top so there is less chance of losing it as you slide the pulley off the shaft.
You sure your turning things in the right direction? To loosen you should be pushing down on the belt wrench with your left hand and pushing down on the pulley bolt right hand/bolt turning clockwise to loosen.
s2kadrenalin
05-14-2011 07:50 PM
