comptech SC running lean with E/TP/H
Just wondering if any other members are experiencing lean condition under boost with simple bolt on. Seems as though my OEM injectors are maxed out, no matter how high I crank the FPR my AFR's stay in the 13's in third gear around 6 thousand RPM and up. Thanks for your help guys. BTW I'm running a 7lb pulley
Originally Posted by Irvatron,Apr 15 2010, 05:55 AM
Told you a few timed check that the voltage at the fuel pump is more or less the same as the battery at idle.
I'm 100% sure the Walbro is real.
Originally Posted by \\s2kris//,Apr 18 2010, 11:50 PM
just finished the fuel pump no improvement. still running lean. I picked up 440's and an emanage ult. ill have to see if this fixes the lean issue.
