Comptech SC...do i need to upgrade...
Old 07-22-2005 | 05:28 PM
Ptt4Dgh's Avatar
Default Comptech SC...do i need to upgrade...
I am in the process of purchasing a Comptech SC and I have been told and read that it is a good idea to upgrade the clutch and flywheel. My question is do I need to purchase a new clutch kit or just the clutch disc? Also is the Fidanza flywheel a good replacement?
Sorry if these are repeat questions, I tried searching for a while with no luck. Thanks for all the help.
Old 07-22-2005 | 06:19 PM
Black Nugget's Avatar
Highly recommend the Comptech Kit from Jeff & Joe at hardtopguy.
Thats what I'm using on my comptech kit & love it
Old 07-22-2005 | 08:00 PM
FF2Skip's Avatar
Pressure plate is the key. If you're going to open her up for that, you might as well get the other items installed at the same time, but they are not necessary.
I agree with BN. If you need anything, check with Jeff/Joe first.
Old 07-22-2005 | 08:29 PM
koala's Avatar
Lot's of people run a supercharger with no other modifications.
xviper is on the stock clutch and flywheel. It really depends on how hard you want to drive the car.
Old 07-22-2005 | 09:55 PM
GoFaassttt's Avatar
On the original stock clutch and flywheel myself with 45k miles in total and 27k of them supercharged.
Old 07-23-2005 | 07:18 AM
Ptt4Dgh's Avatar
thanks for the input guys.
Old 07-23-2005 | 11:09 AM
Silver S2k4's Avatar
I would strongly recommend upgrading because the stock clutch can not handle high rpm fast shifts and will slip greatly if you run it hard.
Old 07-23-2005 | 03:23 PM
D-S2K's Avatar
like the above mentioned, the clutch and flywheel kit is great to have when blowned.
however, my car is supercharged and is running on 9 psi without a clutch kit, and it's running fine with no slipping.
i guess it all depends on how hard you drive your car and your preference.
Old 07-23-2005 | 05:39 PM
xviper's Avatar
IMO, it's not just "how hard your drive your car" but more to do with "how you drive your car hard". This statement will only be clear to you if you understand what I just said. (Not in a mood to explain it.)
Old 07-23-2005 | 05:57 PM
GoFaassttt's Avatar
^ I agree.
Quick Reply: Comptech SC...do i need to upgrade...
