comptech SC with AC HELP!
hello, i just bought a used comptech sc with AC kit from one of the member here. the problems is he didnt send me all the parts from the kits because his local shop didnt take out all the parts from his car.
here is the missing parts from the kit
ESM
Fuel pump
Fuel pressure regularor
Oil pan fitting
Mounting washer parts ( 4 metals and 2 rubber)
i think those parts are still in his car, but my question is can i used the aftermarket parts instead of comptech. is it gonna work. For example can i use the other brand Fuel pump........ and also some of the washer from the kit is missing. can i still be able to mount it on my car without problems?? Thanks for your help.
ESM
Fuel pump
Oil pan fitting
ESM
Fuel pump
Oil pan fitting
ESM
Fuel pump
Oil pan fitting
If I were you, I'd check with "Hardtopguy". He may have some extra Comptech parts laying around
ESM - Basically, this is a "voltage clamp" for the MAP sensor. You can try one of these: http://www.splitsec.com/products/clamps.htm
Fuel pump - This is an off the shelf Walbro 255lph in-tank fuel pump.
Fuel pressure regulator - Somebody once identified who manufactured this part for Comptech, but I can't seem to find that link. Well, it's basically a rising rate FPR, like this one: http://www.racetep.com/begireg.html
Oil pan fitting - According to the instruction manual, this fitting is a [B]14mm to
jmrobins
Member S2000 Classifieds and For Sale
15
09-16-2004 05:59 PM
