Comptech S/C
Old 12-21-2005, 07:56 AM
mikeyfei's Avatar
Default Comptech S/C
I currently have a J's Racing straight pipe, and the Top Secret Ti cat back. I ordered a Comptech S/C w/ A/C kit, are all these compatible? Also, will the engine management that comes with the kit be sufficient, or do I need another?
Old 12-21-2005, 08:14 AM
Black Nugget's Avatar
Everything will bolt right up without a problem! The Comptech Kit is very thorough, you will be able to just bolt everything on and be good to go. You don't really need to be looking into any sort of engine management unless you are planning to use a 9psi or higher pulley.
Old 12-21-2005, 08:15 AM
mikeyfei's Avatar
thanks for the info!
Old 12-21-2005, 08:22 AM
xviper's Avatar
Comptech doesn't supply a real "engine management" device. It's called an "ESM" (Electronic Signal Modifier). It's just a simple MAP clamp to hide boost from the ECU.
Old 12-21-2005, 09:14 AM
mikeyfei's Avatar
xviper- is that enough? I don't plan to increase the boost or change pulleys or anything like that.
Old 12-21-2005, 09:53 AM
xviper's Avatar
It has been "enough" for years for more S2000s than you can "shake a stick at". In fact, Comptech is so confident in their kit that when installed at a Comptech authorized dealer or shop, you will maintain your warranty coverage. As long as you don't "mess with it" to extract more power in a "non-Comptech" approved manner, this kit should perform reliably for a very long time.
Old 12-21-2005, 03:12 PM
ayS
ayS's Avatar
Old 12-21-2005, 07:41 PM
stitos2k's Avatar
Comptech's customer service is damn good too. You call them, they will try and help you!
Vortech wouldn't return a call even their building was on fire and the fire department was calling for directions.
Old 12-22-2005, 07:55 AM
mikeyfei's Avatar
well, thanks to all who gave advice, my confidence in my purchase is bolstered, as is my confidence in my car's ability to handle it. thanks again.
Old 12-22-2005, 12:23 PM
ayS
ayS's Avatar
it should be fine. i boosted at 4300 miles.
Quick Reply: Comptech S/C
