Comptech Kit - Whirring/Low Frequency Hum On Throttle Closure at 4k+
Old 12-22-2019 | 11:40 AM
s2kvince's Avatar
Default Comptech Kit - Whirring/Low Frequency Hum On Throttle Closure at 4k+
I have a Comptech Novi1000 on my AP1. Recently, I've noticed that it's making a whirring or low pitched noise above 3500-4000 RPM that only occurs when the throttle blade is closed. It's most audible from the air filter. It sounds like a large fan blowing. I don't notice any difference in boost or performance.
Could this be related to a bad bypass valve? It seems like it must be something caused by the pressure build-up when the throttle blade has air flow to the engine blocked off.
Old 12-23-2019 | 04:28 PM
EOE's Avatar
EOE
YES. In my case it was the Bosch bypass valve that I got on Amazon. Turned out to be a knockoff unfortunately. Immediately failed and it was exactly as you described.
edit: I no longer purchase, even reputable, parts on Amazon due to knock-offs.
Old 01-03-2020 | 09:48 AM
s2kvince's Avatar
Thanks, confirmed that mine was also a failed Bosch bypass valve. Noise went away with a replacement.
Lovetodrive2000
03-26-2020 10:53 AM
RAP1D
20
03-01-2019 02:35 PM
BearNVa
08-31-2018 07:23 AM
ajhughes
07-08-2017 05:37 AM
Quick Reply: Comptech Kit - Whirring/Low Frequency Hum On Throttle Closure at 4k+
