comptech esm wiring
comptech esm wiring
sorry guys, i dunno if i should've kept the old thread or not but i got another question.
i found this esm wiring configuration:
Comptech ESM Red Wire (Power) -> ECU Pin 19 Yel/Red Wire
Comptech ESM Black Wire (GND) -> ECU Pin 7 Grn/Wht Wire
Comptech ESM Green Wire (Signal) -> ECU Pin 17 Grn/Red Wire
Comptech ESM Blue Wire (Signal) -> To MAP Sensor Grn/Red Wire
but that didn't specify to cut the map sensor wire. after i found another diagram:
https://www.s2ki.com/s2000/uploads/g...1091513337.jpg
in the second diagram, it said to cut the map sensor wire, is that necessary? and why? and also does it matter which wire is on which end (ecu-->green-->ecu-->blue-->map sensor)?
much appreciated, Thanks!
