comptech ctsc with aftercooler--IAT'S TOO HIGH
Old 08-22-2011, 01:27 PM
wait4vtec's Avatar
update: i looked up the GPH(output) on the pump and broke the numbers down and tested it and the pump works great
i then began to "flush" the aftercooler out and plenty of gunk came out so i got all of that out and did the same to the heat exchanger and some stuff also came out of that
i was surprised how much dirt/particles etc came out,im pretty sure that was my problem
tomorrow morning i am droping the cooler off to get ceramic coated as well
i also want to run distilled water and water wetter instead of 50/50 antifreeze/water...WILL THIS BENIFIT ME AT ALL?
IF SO how much water wetter should i use?
Old 08-22-2011, 01:40 PM
wait4vtec's Avatar
just did some research and found some info on water wetter from a guy who makes aftercooler kits for K motors so im going to run about 1/4-1/2 bottle of water wetter and the rest distilled water
Old 08-22-2011, 01:44 PM
wait4vtec's Avatar
one other question, if someone could please give me thier thoughts on this
as of now i just have an air filter clmaped directly onto the blower with my FMIC set up on and my iat's stay around 120-135 when stoped in 90-100 degree temps outside
once i put the fixed/ceramic coated aftercooler set up back on,i also plan to make a custom cold air intake so this should also help lower my iat's CORRECT?
Old 08-22-2011, 03:08 PM
s2000Junky's Avatar
More so when your moving. You will probably see a rise in stop and go traffic compared to your fmic. 120-135 is pretty good on a 100 degree day. Your going to gain about 3-4psi however so plan on a retune and more powa!!!
Old 08-23-2011, 01:05 AM
s2kadrenalin's Avatar
^This.
Glad the clean out worked for you.
Old 08-23-2011, 12:33 PM
Banned
Kyushin's Avatar
130-140 moving is what I see on a 100 degree day but its been more like 110+ in this shit hole AZ. My next step is going to be some thick layer of Jet HOT on the aftercooler to virtuallly eliminate heatsoak from the engine bay.
Old 08-23-2011, 06:46 PM
wait4vtec's Avatar
Originally Posted by Kyushin
Originally Posted by s2000Junky' timestamp='1314054531' post='20903158
[quote name='wait4vtec' timestamp='1314049463' post='20902892']
[/quote]
yeah i just dropped my aftercooler off this morning to get jet hot coated! hope it does its job!
Old 08-23-2011, 07:26 PM
s2000Junky's Avatar
[/quote]
If your car can survive AZ, you can drive it anywhere on the planet lol
lude92_si
07-16-2013 02:59 PM
myflys2k
Southern Ontario For Sale
25
05-25-2010 06:51 AM
Bdiddy
Member S2000 Classifieds and For Sale
40
02-28-2007 08:11 PM
TheCop
03-17-2004 09:23 PM
Yellow Streak
13
08-13-2003 05:27 AM
Quick Reply: comptech ctsc with aftercooler--IAT'S TOO HIGH
