Compression test
That number is too high to do the oil test. The extra oil alone will bump that number back up to normal whether your piston ring is bad or not. I suggest a leak down test. Have you done a valve adjustment recently?
I was pretty sure that I had a cracked ring but it turned out to be burnt/cracked valves. I had only 120psi on that cylinder.
mrkim019
11-28-2005 10:02 AM
