Clutch Upgrade for SC'ed S
Hi, I am about to SC my car with a vortech kit.
and before I go ahead, I need to get my clutch sorted out as its slipping very bad now.
I only plan to run standard boost with the Vortech kit, and was wandering which disk / pp to go for that would hold nicely and also be daily driveable!
After searching I thought,
OEM Clutch Disk + ACT Heavy Duty Pressure Plate
might do the trick? or is the OEM clutch disk not enough to stand the extra torque from SC'd engine?
I need some advice..
Thanks
Thanks
Originally Posted by Eri_S2k,Sep 24 2007, 07:47 AM
I really don't trust the OEM DISK and ACT Plate, I had it in my S and don't worked for me
Get a Beefier Disc like a 4 puck or 6 puck disc and the ACT Extreme Plate!
Its holds gobs of Power!
how much power are you putting down?
Also I guess the 6puck disc will also be a very noisy clutch..
Originally Posted by dwedge,Sep 24 2007, 09:01 AM
wouldn't the 6 puck disc make it not so driveable everyday???
I installed a cluthmasters clutch on a S2000 and it seem very nice. it was about 900 lbs over stock PP.
I need some opinions on clutches, I need one soon.
do not get the CC stge 4, with 6 puck, if you don't want lots of decel buzz and less that OEM clutch uptake.
My friends who are making more torque than me are running the ACT PP with OEM organic clutch and are not slipping at all.
