clutch slipping
Inline has a sale right now on all their competition clutches in the engine group buy section. get the 6 puc and call it a day if need be. 500 for the clutch package and 700 with the lightened flywheel.
Originally Posted by AndyFloyd,Jun 6 2009, 11:33 AM
im making 360ft/lb on racefuel with that same clutch no issues. How much torque are you putting to the wheels? Its rated at like 380-390 ft/lb.
Originally Posted by camuman,Jun 7 2009, 07:18 AM
the 380-390 max is flywheel rated tq. with bsaic 15% drivetrain loss you should be at 414, past that clutches rated tq.
Originally Posted by chansta,Jun 7 2009, 09:23 AM
it seems like the clutch is capable of withstanding your hp/tq... did you machine / replace the flywheel as well when u upgraded to the ACT clutch?
Did you properly break in the clutch? Or did you start whailing at it with all 400hp right after the install.
A new clutch is like new brake pads, you need to bed it in with the flywheel to get optimal results.
My guess is, your clutch is glazed over
DFul4d
07-30-2003 06:40 AM
