clutch slipping
Old 06-06-2009, 07:04 AM
killabee's Avatar
Unhappy clutch slipping
Ok I know that this has been disscused a millon times but I cant find the info I am looking for threw the search. my problem Is that I running forced induction and I am putting down 421hp and my act clutch Is not holding up anymore. It was doing fine for the first 1,000 or so miles but now It Is slipping. so Im thinking the cheapest route for me would be to take out the street/strip disc and step up to a puck disc rather than buying a whole new clutch kit from say clutch masters. I dont have alot of money right now I just want to get the power back to the ground.
any info would be great.
Thanks Brian.
Old 06-06-2009, 07:33 AM
AndyFloyd's Avatar
im making 360ft/lb on racefuel with that same clutch no issues. How much torque are you putting to the wheels? Its rated at like 380-390 ft/lb.
Old 06-06-2009, 07:41 AM
killabee's Avatar
I am putting down 297ft/lb and It Is slipping.
Old 06-06-2009, 08:09 AM
AndyFloyd's Avatar
thats odd man, well yea you could just use a puck disk with it and that would increase its holding ability to over 400 ft/lb i would bet.
Old 06-06-2009, 08:14 AM
camuman's Avatar
no to puck. readjust your clutch rod. i bet its adjusted wrong.
otherwise, clutchmasters stage 3
but i would readjust first. theres a video on this site of a dude doing the adjustment, its supereasy and makes a world of sense
Old 06-06-2009, 08:17 AM
killabee's Avatar
I am starting to think maybe my clutch is not disengaging all the way and maybe thats why It falied so soon. has anyone eles had this problem with act clutch?
Old 06-06-2009, 08:20 AM
killabee's Avatar
I dont think that Is the issue. It does not slip until I get to higher rpms under full boost.
Old 06-06-2009, 08:36 AM
camuman's Avatar
if its not adjusted right, then its not fully engaging either. its worth a try, cause its FREE
otherwise, clutchmasters stage 3 will def hold that power. u make hi 200+ tq right?
Old 06-06-2009, 08:51 AM
killabee's Avatar
I didnt even think of It that way. how would you adjust It.
Old 06-06-2009, 09:28 AM
camuman's Avatar
https://www.s2ki.com/forums/index.ph...f=142&t=699226
watch this video and try what he says. worst case you still replace the clutch. but worth a shot.
Quick Reply: clutch slipping
