Changing oil with Comptech SC
I've recently installed a comptech unit on my car. I can no longer use my fumoto drain valve.
It's now rather a pain in the ass to change my oil, because of the big hose in the way (making it impossible to use a socket wrench), lack of access, and my x-brace makes it more difficult to get a box wrench in there.
Is there an easier way?
You could always switch to the Muz/Whiteline x-brace which doesn't block the drain plug.
The fumoto isn't going back in unless you remove the oil pan, and add a fitting for the return hose like the Vortech SC.
I don't like the Comptech fitting much. I found that when I went to undo it it would always loosen the fitting into the sump rather than the AN fitting. And I certainly wouldn't want a T-piece or adaptor down there. It's exposed enough as it is.
I'd say tap the sump for the comptech and reinstall the Fumoto or just leave it off.
As for X-braces, you can't go past the Muz for convenience.
Originally Posted by honda9krpm,Sep 7 2005, 05:01 AM
btw how safe is the fumoto?
It really makes oil changes so much easier.
NZ
