Can't get past 6000 rpm's?
Originally Posted by Dsgs2k3,May 31 2007, 05:12 PM
let us know
Its a hit or miss thing or at least it was. My fluids are all fine coolant hasn't moved oil hasn't moved. I check them any tim that I stop just to make sure. I don't know ?? we shall see tomorrow . Why is it that anytime before I put the turbo on I seen a million 350z's that wanted to play. I start putting 330 hp to the ground and they are all gone??? Dammit.
Alright I swapped out the MAP sensor and it was fine until today when I started driving it hard on the wa home from work. Again it just starts cutting off around 6000 rpms. No real reason why that I can think of besides maybe it getting hotter??? Anyone have any idea what I could check????
Originally Posted by revhi,Jun 3 2007, 05:40 PM
What volatge is the map clamp set on?
If its not clamped properly, the MAP sensor can act funky / detect boost / etc and might cut power.
I'd check that and your vtec settings. Something isn;t right with the tune.
The vtec settings are being bypassed. We thought we were having issues with the emanage so we are just going off of the ecu for vtec. I wonder if this could be a part of the problem. The MAP sensor is 3 days old. How could I change the clamp manually?? Or does it have to be done with the emanage.
Who tuned it? Ecu vtec is fine. I dont know how to change it with the profec B, only from the actual program. Its not always 2.9v. On the program you can see what your voltage sits at normally and set it to that. Mines set at 2.86v.
